1998 cbr600 fuel valve
Old May 4, 2024 | 10:26 PM
smokingjoes's Avatar
Default 1998 cbr600 fuel valve
Hey guys I have a 1998 cbr600. I need a new fuel valve. Its my understanding that the f3 valves do not have a vacuum line while the f2 valves do. I'm looking at a cheap valve from Amazon. They all say compatible with f2&f3. But every single one has the vacuum line. The stock valve doesn't have a vacuum line. Can I just plug it off or will it work?
I got the bike cheap and don't want to dump too much money into it.
This is what I'm looking at:
Fuel Valve Petcock Assembly For HONDA CBR600 F2 F3 CBR 600 1997 1998 1999 2000 https://a.co/d/5CJzyoc
Any advice would be much appreciated.
Old May 5, 2024 | 04:59 AM
Ed Harris's Avatar
You cannot just blank the vacuum pipe off, the valve will not pass petrol without a vacuum, but it should be easy enough to run a hose from the vacuum take-off point of one of the carbs to the valve.
Question is, why not just get an F3 valve? Breakers must have them.
Old May 5, 2024 | 09:10 AM
Thanks for the info.
​​​​​I cant seem to find one, I'm not sure what you mean by breakers.
Old May 5, 2024 | 09:24 AM
Breakers is the UK term for junk yard (loosely).
Old May 5, 2024 | 09:34 AM
Ed Harris's Avatar
I don't know what you call them in the US but a scrap yard that breaks bikes and sells the parts.
Old May 5, 2024 | 03:06 PM
dannoxyz's Avatar
eBay's good source for used/NOS parts for older bikes. Yeah, they get F2 mixed in there as well, but some are genuine F3 petcocks without vacuum port.
ebay - CBR600F3 petcock
Probably better to get old used OEM unit and rebuild with All ***** kit.
Old Jun 13, 2024 | 04:58 PM
kylehasyourfrenchtoast's Avatar
I’ve had about 4 aftermarket Petcocks and 2 OEM petcocks and they’ve all seized where I was unable to switch from Off, to On, or Reserve. Made plenty of messes having them stuck in the on position.
The manual says should only switch to OFF for long term storage and Reserve if run out of fuel. Am using an aftermarket one and is just fine.
Old Jun 18, 2024 | 02:41 PM
Found one on eBay with dannoxyz link. Bike is up and running. Thanks for the help guys.
tonyhaas28
Sep 24, 2011 03:16 PM
Weidenheft
Oct 26, 2009 08:16 AM
jesseh11
Jul 8, 2008 05:18 PM
orofinocbr
Mar 3, 2008 11:51 PM
