Clutch problem!!! Please help!!!
Old Jul 20, 2012 | 07:38 PM
Lovemyhonda's Avatar
New Member
Default Clutch problem!!! Please help!!!
Hi i just replaced my old clutch with a DP clutch. I followed all the steps of installation and torque specs correctly from the haynes manual 2070. So I started the bike and dropped it into first gear and nothing it just dies. Another problem i noticed was that when i started the bike in first gear with the clutch lever squeezed in the bike would go forward without letting go of the clutch lever. I have adjusted the clutch cable many times. Seems like the clutch wont engage or disengage? Any advice would be much appreciated! Thank You!!!
Old Jul 21, 2012 | 05:42 AM
VEXD's Avatar
Can you feel a biting point on your clutch lever at all?
Old Jul 21, 2012 | 09:26 AM
Is it possible you left item #15 out from this page ? F3 Clutch. Are you able to move item #7 here with just your hand ? Right Crankcase Cover. Does your clutch lever feel real soft and easy to pull ?
Old Jul 21, 2012 | 08:26 PM
New Member
Yes the clutch lever bites and has tension. The clutch lifter is also installed correctly. No I cant move the clutch lever by hand on the crankcase cover, but I did get a screwdriver and wedged it so i could move it.
Old Jul 24, 2012 | 04:01 AM
VEXD's Avatar
It sounds like you did everything right, but I would say that you should be able to move the lever by hand a little bit, depending on your strength.
My expertise in non-existent here, so I'm going to butt out but I think the only real answer I could give would be that it sounds like you have gotten something wrong during installation, and you are going to have to undo and re-do most of your work.
If you tightened down the clutch plates too far on the springs, that would be trouble.
If you used the correct torque settings, then you have attached something else incorrectly.
Good luck and I hope you fix it!
Old Jul 24, 2012 | 10:17 AM
cobra1000rr's Avatar
how about a pic of the clutch cable adjustment, so we can see how you have it set. If you did the clutch plates and all correctly from the book, then its got to be the adjustment of your cable. You might have to run back over your work and recheck everything. did the clutch lever grab the push rod? this can be a common issue with redoing a clutch.
mlrtime99
Oct 10, 2007 03:11 PM
smak_blaze
Mar 30, 2007 05:40 PM
lowrinlife
Jul 30, 2006 02:18 PM
lowrinlife
May 27, 2006 12:18 PM
lowrinlife
May 26, 2006 09:21 PM
