Chain tensioner
Old 08-07-2010, 10:46 PM
Nevets's Avatar
Default Chain tensioner
Tips on replacing chain tensioner??? Mine is sorta bent and cracked! :O...
Old 08-07-2010, 11:07 PM
spicymeowmix's Avatar
Official Welcome Crew Spicy Cat
theres 2 stickies on it
Old 08-07-2010, 11:26 PM
Nevets's Avatar
Yeah browski, plenty of info in stickies on cam chain tensioner, but I'm tackling the legit chain tensioner... In the swing arm.. Maybe I missed it, but I don't think that is the case.
Old 08-08-2010, 01:19 AM
ah you mean the drive chain i got ya.
to replace them you have to remove the wheel, and then the axle.
then they slide out.
Old 08-08-2010, 08:36 AM
Well, if we wanted to split hairs here, you have to remove the axle first before you remove the rear wheel... lol. Then, strictly speaking, you don't even have to remove the rear wheel, the adjusters will just slide out with the axle removed. Just messin with ya Spicy...
Old 08-08-2010, 09:20 AM
nice one dirt.
while you are changing those adjusters, you might want to look into doing all the work you can back there, eg. change break pads, new tire, lube the axle.
Old 08-08-2010, 10:20 AM
Nevets's Avatar
I'll also lube the axle, haha.. Brake pads will come later and the rubber still has a few thousand left on it... Thanks for the input though!
Speedemon636
05-08-2010 06:27 PM
njens118
05-04-2010 03:44 PM
nikos
02-25-2009 02:05 AM
ozrider
02-07-2006 02:02 PM
radio one
11-08-2005 11:38 PM
Quick Reply: Chain tensioner
