Chain tensioner
Tips on replacing chain tensioner??? Mine is sorta bent and cracked! :O...
Originally Posted by Nevets
(Post 954987)
Yeah browski, plenty of info in stickies on cam chain tensioner, but I'm tackling the legit chain tensioner... In the swing arm.. Maybe I missed it, but I don't think that is the case.
(Post 954994)
to replace them you have to remove the wheel, and then the axle. then they slide out. |
Originally Posted by spicymeowmix
(Post 955010)
ah you mean the drive chain i got ya.
nice one dirt.
while you are changing those adjusters, you might want to look into doing all the work you can back there, eg. change break pads, new tire, lube the axle. |
I'll also lube the axle, haha.. Brake pads will come later and the rubber still has a few thousand left on it... Thanks for the input though!
