Chain and sprocket question
Old Aug 19, 2013 | 11:04 AM
cmartino88's Avatar
Default Chain and sprocket question
It is time for me to change the chain and sprockets on my bike, as well as the tires...I figure I might as well do it while its all taken apart. Anyway I'm diverging from the stock specs on the sprockets and the chain going down one in the front to 14 teeth, and up one in the back to 44 teeth with 520 pitch. The stock chain is 108 links and my question is, will the chain length change or will it stay the same? I'm thinking it should stay the same because the total number of teeth between the sprockets isnt changing but I'm not sure if pitch or anything plays a factor. Thank you all in advance for the help and I apologize for making this so long.
Old Aug 19, 2013 | 03:31 PM
kidd6674's Avatar
Default same ? i have!!
i have a 2006 honda cbr1000rr it has a 530 chain 16/42 sprocket and i would like to change to a 15/41 sprocket set up i wanna know the pro and cons to this...and how do i know the length of my chain thanks in advance...
Old Aug 19, 2013 | 03:42 PM
74demon's Avatar
The chain length should be the same as stock with a -1/+1
Why would you want to go -1/-1?
If you start your own thread in the 1000rr section, the RR guys will point the way.
Old Aug 19, 2013 | 03:53 PM
kidd6674's Avatar
ok going to start a thread right now and thanks..
Da11en47
Feb 11, 2010 07:54 PM
Indiana Hurricane
Aug 30, 2009 01:08 PM
j_emmette
Aug 1, 2009 11:59 AM
DragonCBR
Feb 11, 2008 09:46 AM
BlindLOKI
Mar 12, 2005 06:12 AM
