CBR F3 Headlight issues
hey guys, new to the forum!
recently I replaced my wiring harness after a huge rectifier failure, and now I’m putting the bike all back together. I have everything plugged in and everything is good to the best of my knowledge, however neither the high beam light on the dash, nor the actual running low or high beam on the light work. Does anyone have any ideas where I could have gone wrong? If I need to replace that wire, is it a simple fix?
Definitely use multimeter to trace power flow from battery to headlight. Problem is between where you measure 0v and previous test-point that did have power. This is 5min fix with multimeter.
