Cbr 600f3 problem.
Old Aug 27, 2013 | 06:56 AM
Ohnils's Avatar
Default Cbr 600f3 problem.
Hi.
I have a problem with my cbr 600 f3 98, when i'm driving in 1 gear its no prblem.but when i shift to 2,3,4,5 or6 gear is whee the problem starts.i can give full throttle and it starts to cut, power,no power,power ect.i cant get it to go clean.i have changed sparkplugs,i have cleaned the carbourator.
The problem started after i took of all the plastic,headlight, display and when i washed it.
Any ideas ???
Im sorry, my english sucks..
Old Aug 27, 2013 | 01:35 PM
Will.Bass's Avatar
try disconnecting the air solenoid valve..the plug is on the right side of the bike, on the upper, side of the frame
Old Aug 28, 2013 | 03:25 PM
Ohnils's Avatar
Hi. What will happen when i disconnect it?
Old Aug 28, 2013 | 03:48 PM
Mrmanr's Avatar
If its faulty you will have to bypass it.
Old Aug 29, 2013 | 08:21 AM
Will.Bass's Avatar
it sounds like the air solenoid valve is bad. when you are riding at low speeds..the intake air is from the little hoses behind you front fairing, once you get over a certain speed, your intake air switched to the ram air. (controlled by this solenoid) it sounds like the bike is starving for air..disconnect and the bike should run fine if that is the issue..
Foosh24
Sep 12, 2010 11:21 PM
truluv600f3
Oct 8, 2008 03:19 PM
ptowntsi
May 21, 2007 04:36 PM
NeonspeedRT
Dec 1, 2004 10:45 AM
