Problem getting my 600F3 running.
Old Nov 30, 2004 | 08:16 PM
NeonspeedRT's Avatar
Default Problem getting my 600F3 running.
Ok,
I could use some advice here. I replaced the spark plugs and did an oil change on my 98 600F3 this past week. I finally got the bike to start. I've let it run two or three times now and get up to operating temp. However when I run it, I have to keep the choke up or the bike will die. I've already messed with the idle control and it's still doing it. Also if I rev the throttle and hold it around 4 to 5 k, it just pops non stop. The bike sat for about 6 months. I'm sure the gas is bad. I'm going to drain the tank this weekend and put some good gas in it. Any other suggestions? I'm sure the carbs need cleaning, but i'm hoping thats not it. I don't want to have to mess with them right now. Thanks in advance for any suggestions.
Old Nov 30, 2004 | 09:15 PM
wade280's Avatar
Default RE: Problem getting my 600F3 running.
put some clean gas in it and try to ride/run it for 30-45 min. it wight free/clean everthing out of the carbs. if not you will have to clean them!!!!!
Old Dec 1, 2004 | 10:45 AM
Baldman's Avatar
Add a bottle of fuel injector/carb cleaner and some Water Remover, aka Isopropyl alcohol to the new gas and ride the tank out (not necessarily all at once). Recheck your plugs for fouling/gap afterwards. If you still have problems - perform thorough carb cleaning. Dont forget, always add Sta-Bil (or similar product) to your gas before prior to storage.
LedFloyd900
May 6, 2014 02:18 PM
Ohnils
Aug 29, 2013 08:21 AM
kinggree
Sep 6, 2011 04:15 PM
low4door
Jun 17, 2009 05:11 PM
w/e rider
Aug 27, 2007 12:58 PM
