600F3 not running right
My '95 CBR 600F3 isn't running right! It almost sounds as if it is missing in a cylinder. It was running perfectly fine not too long ago, and I checked the plug wires for continuity and resistance, and they were all good. I changed the plug in cylinder #2 and it ran fine, then I turned it off and back on and now it sounds fouled. Could the carb mixture cause this?
Do yourself a favor: make sure all the plugs are firing and the carbs are clean first. Rejetting the F3 is a PITA and I know from experience it may not solve a darn thing. Wasted weeks and $$$s doing it on my F3 only to find out a solenoid that I bypassed for $0 in less than 15 minutes solved the problem
