carb float problem, please help
Old Jul 13, 2007 | 11:37 PM
rx7turbo287's Avatar
Default carb float problem, please help
need help, my bike is mess up. 1 and 2 carb is filling up with gas when park, even engine not running, the float bypass or whatever you call, is spilling out gas, do i need to take carb apart and fixing it or something i can do?, i don't know nothing about carb, and i am trying to keep from doing that. i took the bowl off and clear out my float with b12, it move freely, is there other thing i can do, anyone come across problem like that before, there's gas in my oil, and engine run like crap. my engine run great for awhile and just this 2 weeks the problem start. already run though all kind cleaner
Old Jul 14, 2007 | 06:46 PM
tgrimaldi87's Avatar
Default RE: carb float problem, please help
to me it sounds like the needle or seat has build up in it to where the needle wont sink in all the way. thats why gas is overflowing because it never stops pouring gas into the carb
Old Jul 15, 2007 | 06:00 PM
so what you suggest to do, rebuild it or clean it, is there site show how process done, never work on carb beforfe
Old Jul 16, 2007 | 12:14 PM
it sounds like It just needs to be cleaned really good. But if your not sure what to do I would try to find a professional who will do it for a good deal. it sucks taking those carbs out let alone putting them back and not having it done right (I just went through it). plus they will know if you have any jets that might need to be replaced
[align=left] [/align]
Old Jul 24, 2007 | 02:49 PM
just try to figure out what to do, local show is going to charge me 110 a carb, to have it clean and rebuild, i talk to someone, he told me remove the float, and di frame(spelling) and soak it in carb cleaner for awhile, not sure is going to be a good idea. i don't know there's any o-ring in the carb, so i don't want it to destory and end up have to rebuild it
Old Jul 24, 2007 | 02:54 PM
MikeInCtown's Avatar
$110???? That's like $440 total!!! I was quoted $300 a month ago and I think that's pretty much going rate according to what I've seen on this board. $440 maybe if you are in New York City.
Old Jul 26, 2007 | 12:23 AM
small town outside of dallas, texas. i know it was too high, i got the float bowl off, and i was thinking using some type cleaner with lube in it, where itll clean it and lube it the same time, made by i can get it to lose it up. taking the carb off is the last thing, there are two brass , look like pick up, for the fuel, i was thinking put the straw though and spray the xx out of it, may be it'll work
skidude88
Jun 23, 2009 08:40 AM
jmanng
Nov 24, 2007 07:29 PM
jasonp
Jun 8, 2007 12:26 AM
Trips
Nov 26, 2006 01:45 AM
