carb balancing
Old Jul 11, 2012 | 09:18 AM
Kitty's Avatar
Default carb balancing
can anyone recommend a decent carb balancer for the f3 engine please? not sure what size connectors I need?
Old Jul 11, 2012 | 10:39 AM
MadHattr059's Avatar
The motion pro are the most common I hear of. They can be found here...
Motion Pro - Carburetor
I actually use the Harmonizer, an electronic vacume sync. It only has a port to sync a
single set, though. I added a aquarium manifold to it to allow easy switching between
the 3 slaves. Works great, He sells from the Adventure Rider's forum, here's a link to it...
Harmonizer Vacuum Multi-Tool -- It ain't your Daddy's Twinmax - ADVrider
If you're gonna do this yourself, you'll also need a right-angle carb pilot adjuster tool
and a d-type pilot-jet tip. The #1 carb on the F3's port is sealed with a 5mm bolt,
(I believe it's 5mm), so you will also need 1-5mm carb adapter tip.
If you do a search on carbs and balance/syncing in the general how-to forums there
are some good threads, as well.
Hope this helps, Ern
Old Jul 11, 2012 | 11:36 AM
Hyperblau's Avatar
I bought a Morgan Carbtune Pro. It's wonderful. Stainless steel columns instead of finicky liquid. www.carbtune.com
Old Jul 13, 2012 | 05:23 AM
Kitty's Avatar
Thankyou just orderd a Morgan Carbtune 4 cylinder balancer
Ruaphu
Oct 4, 2011 01:18 AM
hawkwind
Jul 8, 2011 03:29 AM
drzed1980
Mar 10, 2011 04:52 PM
polter
Apr 17, 2010 08:41 PM
cbroar
Nov 9, 2006 10:57 AM
