brake light dont work
Old Apr 24, 2007 | 08:19 PM
wagonwhatmp5's Avatar
Default brake light dont work
ok heres the problem my tail light comes on like the parking like but it dont light up brighter when i hit the brakes and i also put a diff tail light on and nothing any idears?
Old Apr 25, 2007 | 12:16 AM
pacemaker's Avatar
Default RE: brake light dont work
The rear light is a "dual" bulb, so the light my come on when you turn on the bike, but the fillament for the brake light may be blown. Its a piece or torta to take it out & have a look. other than that, the brake light activation switch adjuster, may turned in to far, so the brake light may be activated all the time.
Old May 5, 2012 | 09:11 PM
George Catalano's Avatar
had that issue after i switched my levers theres a small button behind the front lever that turns it on and off so on my new lever i built a tab to toutch the button to shut the light off ..... if not that i replaced the rear switch and that might of been it too
Old May 5, 2012 | 09:58 PM
estate4life's Avatar
February 2012 ROTM
Does it do that with both front and rear brake? If both don't trigger to brake flare...likely the 2 filament bulb...take out bulb and inspect closely. While bulb is out, use a voltage tester...check if the trigger wire turn hot when you apply brake F/R. If don't have any juice, the it's the connection....
Old May 5, 2012 | 10:32 PM
74demon's Avatar
5 year old thread!!!
Old May 7, 2012 | 04:39 AM
ive about completely fixed my ride with lil tid bits just like that if some 1 would of posted this earlier i woundnt have riden around for a month with no brake light .... love this forum dont even kno how to repay a lot of you guys .... lets just say my mechanic says stuff like ,where u been . my answer should be saving hundreds you rapist ........ im pretty sure ive told u before thanks for being on this site demon ...... soo yea every little bit helps looking forward to picking ur brain about an exhaust i want to fab up kinda like 98frr or spicys but unique like georges
jajgarcia
Jul 24, 2011 11:34 AM
mbrown22
Feb 11, 2011 11:14 AM
phillycbr
Sep 2, 2009 10:35 PM
FLYOU
Jul 13, 2007 08:12 PM
1998f3
Jan 17, 2006 09:54 PM
