Bouncing tacho needle.
Old Jan 3, 2008 | 10:55 PM
netdevil71's Avatar
Default Bouncing tacho needle.
Hi guys,
I had a dead battery in the bike in the carpark of the local shopping centre a few hours ago. I jumped the bike from a car (the car was not running and I had no choice) and it started. The only thing is, on the way home the needle on the tacho was erratic and bouncing all over the shop.Any ideas what could have happened or what the problem might be. I havent started it again since I got home causeI have toget a new battery!
Old Jan 4, 2008 | 06:54 AM
Default RE: Bouncing tacho needle.
Knowing that you've got a bad battery, I wouldn't worry about the bouncing needle until you replace the battery. The alternator in the bike has a tough time keeping the bike running if the battery is not in good condition. I suspect the problem will go away once you replace the battery. If it's still having a problem, then you maybe looking at a voltage rectifier/regulator. But that's later, go with a known.
Old Jan 4, 2008 | 07:47 PM
crashingsucks's Avatar
right before my bike died the tach needle was going all over the place and then within a few seconds it died. I had a fried regulator/rectifier.
Old Jan 4, 2008 | 09:23 PM
Triax's Avatar
That tach should have nothing to do with your regulator. Its a cable so its not electrical. You're cable is probably broken internally within its sleeve and you more than likely need a new cable.
Old Jan 4, 2008 | 09:36 PM
ORIGINAL: Triax
I think you might be thinking of other models. According the the Honda Service manual, the 1995-1998 F3's use an electronic speedometer and tachometer. Voltage fluctuations can cause irratic readings for either the speedo or tach.
Old Jan 4, 2008 | 10:02 PM
Asmittie84's Avatar
Replace the battery. I had all kinds of problems with my bike and most everything was fixed with a new battery.
On my old Yamaha XJ600 I took the gauges out to replace the lightbulbs(Didn't know what wires where to what so didn't want to risk pulling the wrong wire) and went through the front which included taking the speedometer part out and the needle off. For a bit I had the needles jumping around but not bouncing. I finally got it to work properly. But by any chance has your gauges been taken apart before?
But first I'd replace the battery.
Go to Batteries Plus and get an "Extreme AGM Sealed battery". They probably have it in stock and it's only $55 with a core trade in(Valued at $7). Mine's been nothing but good to me even after I killed it hte first day I had it. I killed the bike with the kickstand and not the key and forgot.
Old Jan 5, 2008 | 06:24 AM
netdevil71's Avatar
Thanks for all the help guys, I am getting a new battery on monday so hopefully that should fix things.
SOMMES
Mar 28, 2014 12:12 PM
Rockshoxtora
Feb 24, 2012 11:13 AM
RedBaron
F2 Tech
Oct 27, 2011 10:55 AM
drew0387
Jul 16, 2010 09:06 AM
johnnyx
Jun 30, 2009 05:50 PM
