Bike fell over, now floods out
The carbs were cleaned just before the tip but mixture screws werent touched, with new fuel filter. Brand new, ngk r plugs. Mixture screws are set at 1.75 turns out, but from what i see should it be a 2 1/2 turns out now? Wants to fire up, but it back fires about every 4-5 seconds. No more fuel in the exhaust.
Old plugs
Plug second from the top was with the pilot at 2 1/2 turns out
Bottom was at 4 out
Other two were 3-3 1/2 out
Dont know it this makes it any different but it has a K&N, yohsi exhaust, and a jet kit. Before the tip i only had big idle problems. Bike ran strong enough that rolling into second above 4k would lift the front wheel up.
Old plugs
Bottom was at 4 out
This is what you're looking for.
Carbs tunes to 2.5 turns out. Got the bike start after getting the right order. Starts only with throttle???? But now im back to the same problem as before the bike will only idle at 3500. If im riding to a stop and pull the clutch itll idle at 3500 hang then drop after about 10 seconds till it dies, but if im going about 5 mph and engine break then pull the clutch, itll drop to 1000, starts to studd-er-er-er, then dies, so i cant do u turns at all. Makes me think that the idle jets are clogged so bad that once it drop below 4k the engine has no fuel. Its doesnt bog out, just dies. What makes me think that its is also the idle jets now, is the when i run the bike in anygear move above 1k, it jerks like hell. Bike starts with choke on and off but wont idle correctly with choke on or off
Idling that high would certainly indicate problems with your idle jets. The passageways for the idle circuits are really small and can be challenging to clean. It's not just cleaning the jets that you can remove, it's getting the passageways in the body of the carburetor body clean as well. Soaking each individual carburetor body in a can of carburetor cleaner overnight would be the most effective method. Doing so however requires splitting the carburetors from each other. You'll want to remove all rubber parts from the bodies because the cleaning solution will damage them.
You're not the first person on the site to have carburetor problems and won't be the last. The biggest thing people can do to get them working right is to do an effective job on cleaning them. Baring any damaged parts, when they're clean, they work like brand new.
idle circut is def lean. depending on what u used to clean the brass pilot jets, it may be smart to replace them. compressed air with a blow gun is the best way to clean all the tiny carb circut holes. brass jets are very soft and the tiny holes can be opened up without u being aware. been there, done that.
i always wondered why bikes still had carbs cause they are the reason for so many issues, esp since most have to sit during the off season. i learned to drain the carbs and have always used Sta-Bil in the off season. i would imagine the injectors clog also in down time. fuel injection creates instant throttle response on my bros 2001 cbr xx. i figured it was about the cost but not sure.
Carbs have worked for a LONG time. They are still used to this day on some engines. Ethanol gas has posed a lot of issues, but if taken care of, they will continue to work. I know that fuel injection is better, but if you choose to use the older machines, then you have to learn to deal with them. Just be thankful you do not have points to deal with!
I do remember doing that. I think the last car I had that had points was a 76 Datsun B-210.
