Banjo crush washers
Old Jul 29, 2019 | 05:48 AM
Face310309's Avatar
Default Banjo crush washers
I am needing to replace a caliper and so will need new crush washers.... What size do I need to buy please? And is it better to replace the oem brake set up to a race style set up or keep the original set up but change pipes to braided?
Many Thanks
Old Jul 29, 2019 | 09:38 AM
74demon's Avatar
Change to braided lines. The kit should come with new washers.
After 25 years, the brake hoses have probably seen better days.
Old Jul 29, 2019 | 10:50 AM
Face310309's Avatar
Will do when I have the money next month.... Thank you, was thinking is best to replace, am I right in thinking that popping a double banjo on master cylinder and two seperate line is gonna be better than the one line split into two half way down?
Old Jul 29, 2019 | 11:39 AM
74demon's Avatar
Not sure if it's "better", but it's certainly not worse... Now, eliminating the soft stretchy worn out rubber hose and adding steel braided tubing will be much better.
I've seen people condemn the calipers for sticking brakes, when it's really the restricted old brake hose that is causing the issue.
Old Jul 30, 2019 | 03:37 AM
Face310309's Avatar
Many thanks
MuscleswitCBR
Jan 14, 2011 05:50 PM
Aussiephoenix
Sep 29, 2010 04:32 AM
Hoosier1104
F2 Tech
May 1, 2010 04:46 PM
Bordo
Dec 8, 2009 10:05 AM
cwmc29
Apr 13, 2007 04:42 PM
