ahh..lights
Old Aug 31, 2007 | 06:26 PM
redzintimidator's Avatar
Default ahh..lights
ahhmm...i dont know if its just me..but shouldnt my headlight get brighter when i rev it? Why does mine get dimmer...then go back to bright when its idleing....
any ideas???
Old Aug 31, 2007 | 06:39 PM
land_warrior.rus's Avatar
Default RE: ahh..lights
Some times when your R/R is failing or Stator it dimms the lights when reved. What happens is, when you rev you bring the load up and if the stator is shot it will short circuit not producing enough power. When the R/R is shot it wont be able to manage the extra load when reved grounding the excess it cant handle bringing the voltage down. Check all the ground connections first and then all the connectors. If everything checks ok check the R/R and the stator. good luck. Let me know if you want me to explain how to check them both, i'll do a write up.
Cheers
Old Sep 1, 2007 | 08:07 AM
i have a writeup from abadfish. I have a new regulator on its way, but for now i have a reg from a gixxer on it. The resistance in the wires and the stator are all .8 ohm. (A-B)(B-C)(A-C). We'll see how this goes when my new regulator comes in.
Old Sep 1, 2007 | 10:01 AM
Glad yo know what you are doing. Good luck. Post up the final result with the new rr. Cheers
xankriz
Apr 2, 2012 03:02 PM
fordfenatic09
May 17, 2011 10:40 AM
deerslider
Aug 24, 2009 08:23 PM
Ocelaris
Dec 7, 2006 02:14 PM
Moe Blike
Sep 12, 2006 12:40 PM
