98 f3 won't turn ovee
Old 09-02-2013 | 07:49 AM
dad0507's Avatar
The battery reads 12.32v when off. As ssoon as I turn the key the voltage drops to 11.5v and steadily decreases. I took off the front fairing so there is no headlight connected.
  #22
Old 09-02-2013 | 08:08 AM
dad0507's Avatar
Ok so when I pulled off the harness to the starter relay solenoid it looks a bit corroded on the harness end. I tried to stick a small screw driver to scrape off some of the corrosion and plugged it back in. When I turn on the bike and hit start there is a sparking sound coming from the solenoid. How do I clean the harness?
  #23
Old 09-02-2013 | 10:12 AM
Will.Bass's Avatar
that "sparking" sound happens when there is not enough voltage/amperage to hold the solenoid closed to turn the starter..if it is doing that through the normal starting procedure..(key on, run, and start) try hooking jumper cables up to it..let it charge for 5 or so minutes, and try to start it
  #24
Old 09-02-2013 | 10:17 AM
Will.Bass's Avatar
to "clean" the harness? i would say by any means..the copper contacts corrode, so you want to remove the corrosion as much as possible for a clean, unobstructed connection..if it were an easily accessible flat contact, i would suggest a pencil eraser, but being a plug type harness, pretty much any means necessary..
  #25
Old 09-02-2013 | 10:55 AM
dad0507's Avatar
Ok so after I needed to replace the regulator and harness. I cleaned the harness plug at the starter solenoid (gonna buy new spade connectors) and hooked t4he battery up to a charger....... it started!!!!! Thanks for all of the help! I learned a ton!
Stunt'n70f4i
09-06-2010 10:52 AM
Lowridese
05-01-2010 01:12 AM
MrBlaze
08-17-2009 02:07 AM
Cun0144
09-23-2008 10:04 AM
repyosol
09-23-2008 12:55 AM
Quick Reply: 98 f3 won't turn ovee
