98 f3 tach problems?
Old May 26, 2009 | 04:36 AM
satxracer's Avatar
Default 98 f3 tach problems?
ok so just recently ive noticed that my tach keeps shuttin off, particulary at higher speeds, and im just wonderin if any1 else has had this problem before, and if so, how to fix it?? any info is greatly appreciated!!
Old May 26, 2009 | 06:09 AM
pacemaker's Avatar
Could just be a loose wire or faulty sensor, located on the right side crankcase, easy enough to undo, but you really only need to be able to check it out with voltmeter via the white wiring connectors, located on the right rail (under the tank), there are a couple of connectors there, on mine its the 2nd back from the front of the bike.
sjona2011
May 12, 2012 02:49 PM
ncruz4386
May 6, 2012 06:30 PM
criner
Oct 12, 2008 08:17 PM
Lotsokids
Aug 1, 2008 03:29 PM
caseyk29
Oct 20, 2007 05:58 PM
