98 f3 needle clip question
well i kept the throttle cables on (plugged the holes) and flipped the carbs upside down to work on them, and was able to get to them that way.
If you're referring to the clip on the Main Jet Needle that's attached to the bottom of the vacuum slide, then yes you can remove the slide and adjust the clip (aftermarket needles have the clip) without removing the carburetors from the engine.
I can confirm the needle position change with the carbs on the bike is do-able.
It would be easier if my choke rail wasn't tweaked in such a way as to block one of the screws though. I managed by taking off the end w/o the spring. My attempts at bending it only resulted in it being sticky.
Cheers
Cheers
