Lowered needle clip still lean
Old Jun 3, 2013 | 05:33 PM
Ls1Mx5's Avatar
Default Lowered needle clip still lean
I cleaned my carbs, put 140 mains in it, and put the dynojet needle clips on the 4th position from the top (they were at the second before). Past 8k rpm it pulls real hard but sputters up to 8k and makes the lean popping noises as it winds down under 8k. At 1/4-1/2 or so throttle it pulls ok under 8k but when I give it full it sputters, the same way it did above 8k before I put the 140s in. It just doesnt seem logical, i went down 2 clip positions and it still seems just as lean. Any advice would be appreciated
Old Jun 10, 2013 | 10:38 PM
gpfan1's Avatar
Sounds like your pilot jets are not adjusted correctly. The clips on your needle work in reverse. Closer to the top of the needle is leaner as the needle reaches further into the jet.
Check your pilot jet setting. Starting pilot setting for Dynojet is 1 1/2 turns out. Depending on your exhaust setup, you may have to go out to 2 full turns or more. Make adjustments in 1/4 turn increments. Mine are at 1 3/4 turns with 138 mains on a Yosh slip on can.
asides
Aug 11, 2011 03:13 PM
cbreric
Oct 19, 2008 01:01 PM
Stargazer
Sep 19, 2007 06:39 PM
tank_900rr
Jul 14, 2007 07:34 PM
InTheMaking
Aug 14, 2005 01:19 AM
