97 f3 question
Old Aug 17, 2009 | 12:48 PM
Desertfox's Avatar
Default 97 f3 question
Hey guys,
So, i was wondering if not having the guage cluster hooked up on my bike would cause any problems? Such as with the fuel cut off relay or fuel pump? right now, it will start and idle great, goes in first just fine up to about 10 to 15 mph, but when i shift to second and open the throttle it bogs down, sputters then eventually dies unless i pull the clutch and rev it. Ive read elsewhere on here that it is most likely the fuel pump or the fuel cutoff relay, but just wanted to make sure about the guages.
Thanks in advance.
Old Aug 17, 2009 | 02:49 PM
1iwilly's Avatar
or the fuel filter or a clog air filter that not letting air in to balance the air to fuel ratio
Old Aug 17, 2009 | 03:36 PM
hyde's Avatar
check the intake pipes below the headlight.
i had the same problems turned out the pipe had come apart at the T piece where the 2 go into 1 and was not getting enough air in
Old Aug 18, 2009 | 02:52 PM
johnnyx's Avatar
To answer your question, no, the gauges will not affect bike performance. The problem is unrelated.
odano1988
Sep 15, 2015 07:26 AM
bammerman
Jun 12, 2010 12:32 PM
600f4iHUNTERDON-NJ
Oct 8, 2009 10:30 AM
sempul
Sep 11, 2009 09:38 PM
viva_brasil
Jun 9, 2008 04:38 AM
