96 CBR600 F2 front brakes on 98 CBR600 F3 front end
Old Mar 9, 2014 | 07:04 PM
terranzone's Avatar
New Member
Default 96 CBR600 F2 front brakes on 98 CBR600 F3 front end
Hi CBR gurus
new to the forum am currently working on my first bike build.
I ordered a set of front brake calipers off ebay because the seller said it was a 96 CBR600 F3 front brake set. Knew if it was a F3 brake set it should be compatible with my 98 F3 wheel.
I got the brake set from ebay in and never bothered to compare to my F3 front brakes.
Well I finally got ready to put the bike together and saw that the F2 brakes do not match the F3 in size.
Question is: can I still use the F2 brakes on my F3 wheel?
Thanks in advance!
picture is added for reference:
Old Mar 10, 2014 | 06:18 PM
terranzone's Avatar
New Member
no one has any ideas?
Old Mar 13, 2014 | 01:51 PM
removebeforeflight's Avatar
Mock it up in the mean time while you're waiting for a response
Old Mar 13, 2014 | 09:18 PM
coalminer frank's Avatar
From what I understand from what I've read the F2 has solid mounted discs and kind of floating calipers, and the F3 has floating discs with solid mounted caliper, might cause a problem, I dont know. And the F3 has larger diameter discs than the F2, might cause a problem.
Sweeper1
May 10, 2009 04:35 PM
kwong2001
Sep 27, 2007 02:46 AM
alexr40
Sep 19, 2006 04:55 PM
