1996 F3 is leaking fuel
Old Jun 25, 2009 | 06:06 PM
mr93t's Avatar
Default 1996 F3 is leaking fuel
From I THINK the fuel pump.
I cleaned the pump dry, let the bike run, and 1 minute later there was a drop forming under the pump. I think its leaking from the seam.
Can someone recommend me a replacement? Does it HAVE to be a F3 replacement, or will a fuel pump from any bike work?
Thanks for any tips.
Old Jun 25, 2009 | 08:50 PM
Ron Ayers or Service Honda have good prices on OEM. Can't say about aftermarket fuel pumps. Keep in mind that this fuel pump is a low pressure pump, not a high pressure one like you would find on a fuel injected bike. One of those pumps would flood your carburetors because the float valve wouldn't be able to stop the flow of fuel.
Good luck...
Old Jun 25, 2009 | 10:44 PM
edwardzx7's Avatar
Buy yourself some better clamps,i bet that stops the leak!check your clamps!
Old Jun 25, 2009 | 11:53 PM
offspring22's Avatar
I needed to replace mine a couple years back - couldn't be much easier. It was a large leak though. After a couple min there was a large puddle of fuel under the bike. The pump was $65cnd if I recall. The clamps are pretty weak though, I'd replace them with screw style ones
Old Jun 26, 2009 | 09:24 AM
mr93t's Avatar
Hey..where in Canada did you get it?
Also...what clamps are you referring to? I don't see any clamps on the pump. Its just crimped together. I'm not sure what term to use to describe it.
Thanks!
Old Jun 26, 2009 | 09:46 AM
I got mine at GW Cycle in Calgary, a local Honda dealer. If I recall right, they use spring style clamps, kinda look like crimped, but you can use a pair of needle nose pliers to remove them.
Old Jun 26, 2009 | 03:46 PM
johnnyx's Avatar
The Clamps!!!
Old Jun 28, 2009 | 08:38 PM
rotaxhippie's Avatar
I have a 96 F3 fuel pump if you need it. Works perfect. $60 shipped.
Old Jun 29, 2009 | 10:34 AM
mr93t's Avatar
Thanks dudes.
I ended up getting one from the dealer for $150 + tax (CDN).
I hope this one lasts a little more than 25k.
platnumbob
Jul 5, 2014 09:57 PM
Mulkxican88
Nov 14, 2013 05:23 PM
MegatronousPrime
Apr 29, 2012 09:51 PM
robbiebgraham
Mar 8, 2011 02:47 AM
FLYIN HAWAIIAN
May 15, 2008 09:20 PM
