yup.. a swingarm question
Old Jul 9, 2009 | 12:04 PM
morbidphil0622's Avatar
Cool yup.. a swingarm question
I have searched and searched, all I get is bits and peices of info that isnt going to work.
What I would like to know is what the best swingarm swap out there would be for our bikes. I dont even mind swapping to the f4 swingarm if it works. I can weld so fabrication isnt going to be a problem, just wondering what the closest and easiest fit would be. I would still like to use the f2/f3 wheel if I can. any links and info would be wonderful.
I am not however looking to do a single sided swap, the parts are just too high in demand. I would like to swap for f4, f4i, 600rr, 900rr, or any other bike regardless of manufacturer.
thanks..
Old Jul 9, 2009 | 12:21 PM
tundrafiend01's Avatar
If you want to keep the same wheels, why do you want to swap swingarms?
Old Jul 9, 2009 | 02:07 PM
well one reason is that I dont like the steel swingarm as it is very prone to rusting inside and I am near salt water so everything rusts out here. I woulod prefer an aluminum swinger. reason 2 being that I am on the market for a new one as the stock one is rusted out so I figured if I am buying one i might as well get the best one I can.. As far as the wheels go I like the look of the f2 wheels, however I will swap to a newer style if needed. I was just wondering what the easiest swap would be? Just trying to get some answers from somebody who has swapped before..
Old Jul 9, 2009 | 08:50 PM
shardoflard's Avatar
well i do believe unless you find a proper aftermarket swingarm specifically for f2 you will have to fabricate something... sooooo...
http://cgi.ebay.com/ebaymotors/S-199...71410007r18822
i would pick that thing up..
paint/powdercoat it... no more rust problem..
Old Jul 9, 2009 | 10:02 PM
sidewards's Avatar
I have the stocker left over from my swap that I'd sell to you for $20 plus shipping. If you still want to swap, use a 900rr wheel. It looks the same as a f2 wheel but its about an inch wider.
bez
Jul 24, 2010 08:56 AM
dinkk
Sep 16, 2009 01:34 PM
mmookey
TRG Coating
May 13, 2008 06:14 PM
jpruiz219
Mar 30, 2007 06:34 AM
shraz
Aug 16, 2006 01:59 PM
