wont idle
Old May 13, 2008 | 03:11 PM
diabloCBR15's Avatar
Default wont idle
my 91 F2 will start, but with choke fully out. it will barely idle at 1000 RPMS. what could be the cause? when it initially started, it fired right over and ran for a few min, but then hesitated and now it will only sputter and maybe stay running for a minute or so, but if i touch the throttle it will cut out.
could it be plugs?
carbs flooded?
gas is on. and petcock works
idk whats causin this and i dont want to take it to the mechs.
any advice would be great! thanks
Old May 13, 2008 | 05:18 PM
jakemc's Avatar
Default RE: wont idle
Maybe plugs? When were they last replaced? I know on my bike if I haven't started it in a couple of days I have to have the choke fully on. After a little while I will slowly open the choke and it will run fine. Not sure if that is your problem though.
Old May 13, 2008 | 08:23 PM
Perfect Grade's Avatar
When you say the choke is 'fully out', do you mean it's engaged (open), or disengaged? (closed)
Old May 13, 2008 | 08:26 PM
open. as if warming the bike up..
Old May 14, 2008 | 05:52 AM
woo545's Avatar
Sounds like a fuel related issue to me. Check the fuel lines. Pull the carbs and make sure all the jets are clear. Clean carbs too while at it.
Old May 14, 2008 | 06:33 AM
MikeInCtown's Avatar
+1 with carb issues. Try to see if it will start with no choke, but some throttle. Chances are you got some dirt in there somewhere. Also, with choke full on it's possible one plug may not be firing which could account for the low RPMs and porr performance and sputtering.
Anyway, clean out carbs and change plugs. Also make sure air filter isn't overly dirty.
Old May 14, 2008 | 09:39 AM
carbs were cleaned already. which leaves fuel and plugs.. i'll check those today and get back to ya
Dustin12002
Apr 3, 2013 11:42 PM
Morganjh17
Apr 25, 2011 06:36 AM
greenheep
Sep 7, 2010 06:28 PM
89cane
Jan 15, 2008 11:16 PM
TwistedCBR
Dec 13, 2006 12:14 AM
