96 cbr f3 wont idle without choke
Old Apr 2, 2013 | 03:57 PM
Dustin12002's Avatar
New Member
Default 96 cbr f3 wont idle without choke
Hi i have a 96 cbr f3 and it was running great the other day and i took the carbs off and cleaned them jets and all but i didnt mess with airfuel mixture screws, i also changed fuel filter and put a k and n air filter on it and now, it will only run with choke on and if you turn the choke off it will stall,also if you try to rev it with the choke on it stalls. any help would be great thanks
Old Apr 3, 2013 | 11:30 PM
cc rider's Avatar
The bike should not run worse AFTER you clean the carbs. This problem usually indicates a dirty jet problem. Unless , you didn't put something back correctly. I would try pulling them off and going through the process again making sure everything is correctly reinstalled. Did it do this right after you cleaned them and reinstalled them? Or did u ride it for a while then it started acting up?
Old Apr 3, 2013 | 11:42 PM
CorruptFile's Avatar
June 2013 ROTM
You may have dislodged crap into the pilot circuit. Is the k&n a very high flow filter? maybe the bike is leaning out?
davidcbrf3
May 15, 2013 01:48 PM
dyracuse
Jan 21, 2010 09:07 PM
radboy58
Jun 14, 2009 11:08 PM
CaliKush
Apr 29, 2009 08:34 AM
Wooderson
Jul 11, 2007 05:49 AM
