voltage regulator problems
Old Feb 12, 2008 | 01:13 PM
rlowride's Avatar
Default voltage regulator problems
I did a search, with no help gined...
my f2 runs good.. starts good etc...
but the V.R right under the right side of the seat.. gets REEEAAAAAAL hot.. the plate it is bolted too is untouchable.. the V.R. smells as if it is burning....
do these just go bad..... should i just replace it???
or do i need to look for an undelining problem first???
Like i said.. everything is working fine... just gets your ***** real warm...
Help...
thank in advance
Rick
Old Feb 12, 2008 | 02:04 PM
rider0033's Avatar
Default RE: voltage regulator problems
if you have a voltage meter then put +to+ and -to- and rev the bike to about 4.5-5 grand. the voltage should be regulated to about 13-14 vdc(dcv). if over replace that baby! the reading your looking at is off the battery(+to+ -to-)
Old Feb 12, 2008 | 02:19 PM
stang68's Avatar
hello ... yes thats going to get hot its called the (Regulator -Rectifier) realy dosint matter and yes that will get very hot if you smell something burning i think you shur check the rectifier wire's there are 3 and thay are yello and also check the wireplug thats what went bad on mying just folow the wire's and check everything
Old Feb 12, 2008 | 03:33 PM
dachamp312's Avatar
Theres a lot of posts on this topic (one that I actually created) but I tested my charging system not too long agoand the R/R was the faulty unit. I had read in a thread that a R/R for a gsxr stays much cooler and is actually a better replacementfor the one the cbr comes with soI purchased one (on ebay for $30 shipped). had not installed yet but I trust the advice...
i'm not ina position to be dishing advice cuz of my noob-ness but just stating my experience and the advice that was given to me.. with that said, for less than 50 bucks you won't have to worry about your ***** being on fiiiiire
or i read on another site that you could mod out the r/r but that may take a lil more effort by messing with the ground wires, adding a copper plate, etc... heres the link to the link: https://cbrforum.com/m_315101/tm.htm
let us know what u decide to do
Old Feb 12, 2008 | 04:00 PM
rlowride's Avatar
if i replace it with the gixxer unit.... is the plug the same?
thanks for the help guys
Rick
Old Feb 12, 2008 | 04:13 PM
dachamp312's Avatar
yea, just be sure to get one with 5 connectors.... i think the colors are different though(i.e. the white on a cbr is actually black on the gixxer)
i pulled this from another thread...
Honda Suzuki
3 white( alternator) 3 black
1 Red ( positive) 1 black/red
1 green( negative) 1 black/white
the white/black wires are interchangeable
Old Feb 18, 2008 | 05:27 AM
rlowride's Avatar
dang, it doesnt stop...........
okay, so i got a new regulator.....
but when i went to bolt it up.. the plug on the wie harnes is all melted up, and unusable...
does anyone have a jacked up wire harness with that plug still being usable that i can get.... or am i looking for a whole new wire harness off of the bay?
thanks in advance for any and all help.....
Rick
cookcbr
Sep 16, 2012 07:37 PM
Jp Provence
Apr 24, 2012 10:36 AM
airick
Apr 29, 2007 07:30 PM
jzcbr600
Apr 1, 2007 07:52 PM
