Under seat storage?
Dammit, I was hoping you had already done it. I've used solenoinds before, so I know a little about them (but I'm sure you know more).I once had a car with shaved door handles, so I used them as door poppers. They only opened about 75% of the time. If there's too much tension on a solenoid, they don't work! It was a pain in the ***! Using them essentially as deadbolts (like we would be in this case) probably wouldn't be a problem.
Sounds like a couple solenoids is the way to go. I'm not an electrician by any means but I know the basics and have people that can help. Is there any way to make it a lock cylinder so its more secure than just a button? Pretty much to upgrade it so that its like most bikes nowadays that you use the key to pop open the seat.
I'm just going to put a button under the left rear fairing so that I don't have to worry about carrying around an extra key, or worrying about having a locksmith match up a locking cylinder to my original ignition key.
ORIGINAL: TripsD
You will be stuck with 2 different keys for your bike this way though.
Oh...and if you go with the push-button swith I would suggest series-connecting it to the off-position of the ignition lock aswell.
Not really needed, but it adds some security in the sense that you cannot accidentally open the seat when the engine is running.
Hootie233
Feb 26, 2019 02:48 PM
linwoodc3
Mar 28, 2012 11:25 PM
420beans
Nov 15, 2009 02:59 AM
