Turn sign./not working.brake light does.please help!
Old Jun 11, 2013 | 04:37 PM
magnumRT's Avatar
Default Turn sign./not working.brake light does.please help!
so iI got my carbs all.cleaned on my f2 and she was alrwady to go and the signals and headlight will not work.new signals and headlight worked before.no juice tobthe headlight or aignal connectors.plain lost.iI did replace my signal relay a while ago.never rode the bike yet. help a guy out?
Old Jun 12, 2013 | 02:54 PM
adrenalnjunky's Avatar
do your signal indicators on the cluster come on and off?
Do any of your neutral/oil/sidestand lights work on your cluster?
If I had to guess none of those work, and your horn probably doesn't work either. check fuse "C" in the fusebox. It sends power to all those things. that is a common point in the turn signal circuits.
the headlamp is off of fuse A - check that too.
Is possible you've broken a ground connection somewhere too - a lot of testing with a voltmeter would be the only way to know for sure.
Old Jun 14, 2013 | 12:09 AM
magnumRT's Avatar
Default Thanks!
Some how the fuse for the.lights and horn had a loose.connection.alilnprobing with tje voltmeter.found tha problem.lil soldering and good to go!
cuban b
Mar 6, 2009 06:22 PM
kao600f2
Aug 23, 2008 12:46 PM
Hayden06F4i
Jun 17, 2008 09:50 AM
FastHatch
May 22, 2007 03:01 PM
teamdfg
Dec 23, 2006 03:40 AM
