need help! ! ! brake light not working ! !
Old Dec 21, 2006 | 05:02 AM
teamdfg's Avatar
Default need help! ! ! brake light not working ! !
need some help, my brake lights does not light up. i checked the fuses, sensors, wirings and everything looks good. Can anyone help me? maybe is a electrical problem?
Old Dec 21, 2006 | 10:49 AM
dwhite645's Avatar
Default RE: need help! ! ! brake light not working ! !
Will it light up when pressing the rear brake by itself? Or the front lever?
* It could be the switch at the rearpedal or front lever
* The second element in the bulbs could be toast, but doubtful both would fail at the same time
Old Dec 21, 2006 | 06:16 PM
teamdfg's Avatar
both front lever and back brake does not light up the brake light..............imma try to get new bulbs and see if that solves the problem...
Old Dec 22, 2006 | 04:28 AM
dragonium25's Avatar
Did you do anything to it recently? Added turn signals? Integrated tail light? Drop your bike? Are you having any other electrical/lighting problems? Could just be a loose connection.
Old Dec 22, 2006 | 11:15 PM
teamdfg's Avatar
i didnt install no new lights and i did not drop my bike.... i checked for loose wirings, and i replaced the bulbs.... still have the same problem.....what else could be triggering this problem??? need help ......bad sensor perhaps?
Old Dec 23, 2006 | 03:40 AM
TK954RR's Avatar
Jan 2009 ROTM
I would check the grounds make sure they are ok. Also grab a test light (a cheapo from autozone will do) and start testing from the lights forward to the switches and see where you have power if any.
MuscleswitCBR
Mar 15, 2011 09:13 PM
cuban b
Mar 6, 2009 06:22 PM
Hayden06F4i
Jun 17, 2008 09:50 AM
FastHatch
May 22, 2007 03:01 PM
ohg35
Jun 22, 2006 06:35 PM
