Tire sizes
Old Apr 27, 2005 | 05:32 AM
Ntense's Avatar
Default Tire sizes
I believe stock size for 91 f2 is 170/60
I am puttin on 180/55
just wanted to see if anyone else has done this and how it worked out for them
Or if anyone knows anyone who did it ..I am just wondering how the handling changes
Old Apr 27, 2005 | 01:51 PM
sirlimpzalot's Avatar
Default RE: Tire sizes
stock is a 160/60-17 and a 180 is not reccomended for a F2, the rim is only 4.5" wide and a 180 is designed for a 5.5" rim. If you put a 180 on it will slow down the steering and will pull the sidewalls in so steeply that if you get leaned way over it may just slip out from under you with no warning. Also your inner fender will not allow the tire to fit without rubbing ( unless you remove it)
A 170 rear tire is the maximum size you should use
Old Apr 29, 2005 | 05:44 AM
Ntense's Avatar
Yes I did remove the rear fender
have you seen it slip out from others?
The guys at the honda shop told me that alot of guys put 180/55 on the rear...they say they dont reccomend it but many guys do it
Old May 9, 2005 | 11:15 PM
bgoode11's Avatar
i had an f2 and i put a 170 on it. i had no problems with it but i cant see how a 180 could squeeze in there..is it really possible??
Old Jun 1, 2005 | 06:36 PM
redhotneon's Avatar
the guy before me put a 180/55 on. ill prolly go down to a 170 when i get a new one
Old Sep 3, 2005 | 05:56 PM
TheFleshRocket's Avatar
sirlimpzalot is dead on--160/60 is stock and a 170/60 should fit fine, but I have never seen an F2 with a 180/55 on it. If you had a later-model F2 with a 5.0" rear wheel, you might have a bit better chance of fitting a 180/55, but to be honest, I can't think of any good reason to do so. The F2 doesn't have anywhere near the power to require a fatter rear tire, and going that wide on a relatively narrow rim will probably negatively affect the bike's handling. And the 180/55 is a heavier tire, which means a bit more inertia to get the bike going, so acceleration might be a tad bit slower too. Stick with a 170/60 and you should be just fine.
Old Oct 6, 2005 | 06:52 PM
clemson725's Avatar
When i bought my F2 years ago it had a set of dunlop 207GP on it. 120/70 on the front and 180/55 on the back. The guys are right. way too big. too steep of a profile. I didnt trust that tire at all. I put new tires on it and went to a 120/60 on the front which was a huge improvement in itsself, and i put a 170 on the back. The 170 tire still folds up on the 4.5 inch rim like the 180 does. If i still had an F2 i'd definitely put a 160 on the back. The bike is engineered for those tire sizes. Another alternative is to put the F3 rim on an F2. it is a 5.0 inch rim and will accomidate a 170 tire.
akiyama640
Aug 26, 2010 02:03 AM
DELANEY134
Jul 18, 2007 08:54 PM
jasonp
Apr 24, 2007 09:06 AM
F3man
May 22, 2006 06:30 PM
SWAT F2
Mar 8, 2005 02:48 PM
