ticking noise when i hook up the choke???
Old Oct 21, 2008 | 02:58 AM
cbrmurphy's Avatar
Default ticking noise when i hook up the choke???
Well when i found out how to hook the choke back up it started making a loud ticking noise coming from the top of the head or right under the gas tank on the right side. So i unhooked it and reved it a lil a the tick kinda went away after a lilttle bit. So i guess im asking. What is it?? thanks
Old Oct 21, 2008 | 03:25 AM
eweppley's Avatar
Default RE: ticking noise when i hook up the choke???
Sort of sounds like the Cam Chain Tensioner (CCT) to me. Its a problem with the F2s. Was it making this noise before you hooked the choke back up too? Put your ear low on the right side of the engine and check if it's coming from there. The noise usually goes away at higher RPMs and after the bike is warmed up, but while it'sdoing it, it sounds like thereare ball bearings flying around inside your engine and its going to fly apart at any second.The CCTis where I would start troubleshooting first. Buy a manually adjustable one andI think there's a good link in the How-To sectionabout installing it.Good luck!!
Old Oct 21, 2008 | 05:44 AM
Hurricane rider's Avatar
you can also convert the stock chain tensioner into a manual one, my Hurricane has it done, and I've got another stock F/F2 tensioner I'm about to hack up for the same purpose.
Old Oct 22, 2008 | 01:21 AM
cbrmurphy's Avatar
Hey yah i actully think thats what it is. Is it hard to put an aftermarket cct on?Also where is it located at?
Old Oct 22, 2008 | 04:08 AM
eweppley's Avatar
Ask and ye shall receive.
https://cbrforum.com/m_217481/tm.htm
Old Oct 22, 2008 | 08:53 AM
woo545's Avatar
What is that mysterious ticking noise?
http://www.youtube.com/watch?v=Tx1XIm6q4r4
socal_cbr
Nov 19, 2008 07:17 PM
quadracer18
Jun 26, 2008 04:27 PM
kllrvet
Aug 8, 2007 01:48 PM
smak_blaze
Jul 25, 2007 10:18 PM
CBRrider01
May 23, 2007 06:13 AM
