Throttle Sticks
im having the same issue my went down and had a bent clip on so i replaced it and it made a huge differance but you can get new cables for like 10 bucks im goin that route and if i still have a problem after that then ill replace the switch
ok what is the right lube to use cuz i tried some stuff and mine are sticking really bad i replaced the cables with brand new ones when i take it off the bar its fine but when back on it goes back when it wants too
Are you sure you don't have a bent clip on? Cause it sure sounds like my 900rr. If i took it off the clip on, it would snap fine, when I put it on the clip on, it binded. I couldn't notice by looking at it that it was bent, but it was. I replaced the clip on and it worked just fine. You can usually pick up clip ons pretty cheap
Just replaced my cables but still had some issues but i figured it out theres a hole located on the bar that the throttle tube/switch assymbly fits into my problem was the pin was too long along with the plastic located next to its so i grinded down the pin and plastic untill the throttle was really smooth it could be something you might be having with
