Throttle Sticks
The stuff I use is pretty awesome... I've actually taken to using it on door locks as well. Work better than new.
I tend to use the lube as cleaner... just undo the throttle grip, remove the cables... attach the cable luber and spray in bursts (stops preasure getting too high and it popping open and putting lube all over the dash)... slide the cable in and out a few times... it should feel like almost nothing. Paper towel up any drips from the engine side... Re-attach.. done.
http://www.protectall.com/cable_life.htm
and faq helper material:
http://www.protectall.com/cablelif2.htm
when i got my bike my throttle was slow to snap back too....my bar end was too tight against the throttle...simple but may b your cause...just throwin that out there
exactly the same thing that mine was doing. I had to space the end weight out with a washer and it is perfect now. i just copy and pasted meeson01 post because i dont know how to quote.
Check that your throttle cables are routed so that they are not taking any hard turns, they like to be as straight as possible.
Also make sure nothing is crushing or pinching them.
If you have aftermarket hand grips you may need to cut them down to fit (if they are too long they will rub on the bar end as other people have mentioned)
