Starting help..
Old Aug 13, 2012 | 08:37 PM
Mobotech's Avatar
Default Starting help..
So i just removed and cleaned the carbs, new plugs, replaced gas tank gas filter, air filter oil the works. put it all together it cranked like twice and wouldn't stay on by itself. and after those two times of starting it hasn't started since.
any ideas?
Old Aug 14, 2012 | 07:19 AM
JankCibberf2's Avatar
You didn't plug the fuel line back in that goes from the petcock to the side of carb numbe one that allows vacuum to operate teh petcock
Old Aug 14, 2012 | 09:52 AM
Mobotech's Avatar
Hmm ill check it out let you know what happened.
Old Aug 14, 2012 | 03:27 PM
Mobotech's Avatar
Nope its connected. Still won't start sigh
Old Aug 14, 2012 | 03:33 PM
Mobotech's Avatar
On another note.. When the bike sits overnight and i try and start the next day it will crank then shut right off.
Old Aug 14, 2012 | 04:32 PM
JNSRacing's Avatar
Welcome Crew and ROTY 2014
If it's a fueling issue, perhaps its setup to rich, and it's flooding right off the bat - are you certain that your choke circuit is setup correctly, so that when you slide the lever forward, it disengages the choke? Do you smell a lot of fuel when you try to start it?
Old Aug 14, 2012 | 09:03 PM
Mobotech's Avatar
so its the carbs the jets are real dirty, gonna have to do a jet install thinking of going stage 1
Old Aug 16, 2012 | 01:47 AM
gpfan1's Avatar
How did you "clean" the carbs? Did you alter any of the adjustment screws? Like the butterfly adjusters or idle jet screws. Check the choke cable to see that it is properly engaging the choke bar too.
Old Aug 19, 2012 | 05:11 PM
Mobotech's Avatar
so I found a spare carb in a junkyard that was clean, so now it will start and i will have to play with the choke and the idle to keep it on. so it will stay on by itself at like 3-4k rpms which is high. if it get below 3k it wants to shut off. and the throttle response is a little off.
BlackDogIron
Sep 14, 2017 05:47 PM
Nevets
Nov 8, 2010 04:45 PM
BrokeCollarBone
Nov 24, 2009 01:24 PM
bh1
Dec 7, 2007 02:36 PM
steeper
Jun 23, 2006 02:49 PM
