My cbr story
My cbr story
So last october i bought my first ever bike, an F2 obviously, and along the way ive done little things like hid install, yoshi slip on etc. i brought it over to a local shop to get new tires put on.. They did an all around check of the whole bike and the laundry list read as new rear rotor, front calipers rebuilt, new front brakes, new chain and sprocket. In all, the quote read almost as much as i paid for the bike.
So being mechanically inclined, i plan on doing the work myself. I purchased a RK chain and sprocket kit 530 stock gearing, Galfer rear wave rotor and some OEM caliper seals and EBC brakes.
Most of it is straight forward, the shop mechanic did mention that if im doing the calipers myself, to not let the master cylinder go empty at all cause it was seize it.
so ahead of my i have a somewhat decent job ahead of me seeing ill be doing it alone, but im looking forward 2 it. Is the master cylinder thing true?, if so how would you suggest pulling the calipers while keeping fluid in the master cylinder?
New one on me. If you let them go completely dry, it's a pain bleeding them, though.
There is a really good pictoral 'how-to' on a complete brake over-haul. Do a search on
the general tech forum for 'brakes', you should be able to find it. Check it out and then
come back for the nitty-gritty, if you have specific questions that search doesn't answer.
Ern
Ern
yeah i rebuilt one caliper two days ago, now im waiting on the rest of the seals, i just pinched the hose with some vice grips, stuffed the nut with a rag then tucked it right side up, to keep fluid leak to a minimal..
I was trying to loosen the smaller sprocket but that things on their tight, next attempt im just gonna use air tools.. dont want to risk stripping the bolt.
so my chain and sprocket swap is complete as well as a new rear rotor. shes all put back together and purring nicely. i was all set and ready to get an inspection when the mechanic noticed my brake lights weren't turning on and one of the bulbs in the housing is blown. whats weird is that both rear and front brakes arent working as far as the light in concerned . what would be a good troubleshooting technique to narrow down the issue?
