spark plug
i did mine last year. its not that hard. take off the tank, and unbolt the airbox. like was said before, i also used an extension and i had my bike on a hydraulic lift, so that made it easier being at almost eye level. just keep trying, if i remember correctly, the last 2 were the hardest to reach (the 2 on the throttle side) but you will figure it out. ill try to post some pics if i get time to take it all apart again. Good luck
did mine yesterday starting from left, #1 plug easy, #2 plug little tougher, #3 plug gettin harder, #4 plug i needed smaller hands this one was the hardest not much room to maniplulate my hand, had to unbolt the radiator on bottom so as to swing it out a little and get my hand in to remove old plug and reinstall new plug . the hardest thing was the rubber piece that sits over the plugs i assume its a heat sheild of sorts so i made sure it went back on, had to use a coat hanger to pull it back into place over the radiator fan and rehook on top, all and all it took about an hour or so to do. mine are done!!!!!
