spark plug
Old Feb 20, 2006 | 08:01 PM
F2Woody's Avatar
Default spark plug
whats the easiest way to get to my spark plug or spark plug wire. i'm having truble with my flamethrower and trying to troubleshoot it on the f2.
Old Feb 20, 2006 | 08:16 PM
city worker's Avatar
Default RE: spark plug
let me know how you do it, i have same bike and they look like a f#%$ing bitch to get to, it looks like the radiator needs to be pulled foreward to even get close to the 2 inner plugs i just want to change mine out, but it screams "PAIN IN THE ***!!!!!"
Old Feb 20, 2006 | 09:36 PM
bubba_d_duck's Avatar
i take my tank off of my f2 then the top of the air filter. and right above the air box the frame makes a triangle. and in there their is a plastic rubber. i take that out and the sparkys are right there and easy to get to
Old Feb 20, 2006 | 09:37 PM
hope that helps thats the best way i have found unless you have little hands and can fit them in the side where the small part of the plastics come off
Old Feb 20, 2006 | 09:40 PM
are you talkin about the the whole air box???
Old Feb 20, 2006 | 09:42 PM
just the top.
Old Feb 20, 2006 | 09:59 PM
alright i went out and looked at the bike, the #1 and #2 plug i can reach from the left side, the other 2 the #3 and #4 are under the air box. i have pulled the lid off the air box to get to the element is that the top half you are referring to ? the rubber thing i saw, just work a socket extention down thru there????
Old Feb 21, 2006 | 02:25 PM
yes i use socket extentions to get to sparkys and i usually just pull that plastic thing out its kind of a pain to get back in but not to bad once you get that black plastic peace out you should be able to see the wires and get right to the sparke plugs
Old Feb 21, 2006 | 11:01 PM
F2Woody's Avatar
so let me get this straight. on the left side those two red wires that connect to the boot on the top og the block are spark plug wires?!?!?! you have to pop that boot off just to get to the plug. right now i am just trying to get to the wire.
Old Feb 22, 2006 | 08:13 PM
your right
