Signs of a bad clutch
Old 04-27-2006, 08:33 AM
MT Wallet's Avatar
Default Signs of a bad clutch
How do you know when your clutch is wearing out, needs replacement?
Lately on hills...if I take off from a stop and I am in first gear, with the clutch pulled all the way in....I have a hard time getting the bike to move.... I let the clutch out slow as usual and give it gas but it seems like the bike is almost about to stall.
I have to give it way more revs, like past 2000 rpm to get the bike moving.
Am I doing something wrong? Or is something wrong with my bike?
Old 04-27-2006, 10:26 AM
city worker's Avatar
Default RE: Signs of a bad clutch
I have f-2 also, been wondering when I need to do mine,no prob so far though, but only time will tell [&:]
Old 04-27-2006, 12:00 PM
Krokus_92F2's Avatar
Sounds like your problem is similar to the one I have been having. Does the motor sort of bog down, like it might be flooding, then it hits and takes off real strong? That is my symptom. My F2 has a good clutch, but to maybe answer your question, on my 1982 Yamaha Seca 650, the clutch wore out at 90,000 miles. I would go 70 mph and always the rpms were around 5k. I began to notice the rpms were increasing and the speed was relativly the same. Clutch slippage in high gear was my first clue. Then as it got worse, from a dead stop, the engine would rev but the bike would creep like I had the cluctch lever pulled in, but it was all the way out.
You could have a bad clutch, or you could have the same problem I too am having with my 92 F2, which I have not discovered the cause just yet. This weekend I will tear it down and see what possibilities I find, but I have ruled out my clutch since I can do a second gear wheelie, a bad clutch wouldn't allow that. Hope this helps..........if it doesn't, thanks for reading it just the same. Take Care and Good Luck
Old 04-27-2006, 04:57 PM
MT Wallet's Avatar
Krokus yes it does sound like the same problem!
I have to give it a lot of revs...it's about to bog then when I release the clutch all the way out because the revs are so high it takes off
I hate it
Thanks for your info I appreciate it and city worker!
Let me know what you find after you check out your f2
Old 04-28-2006, 12:04 AM
shiphteey's Avatar
Local Squid had an F3 and didn't know how to do burnouts....so naturally he burned his clutch and tire up!
On Hwy Roll-Ons he kept insisting that his bike wouldn't go past like 75-80 and instead the RPMS would start shooting up like he was in neutral.
Of course his clutch was DEFINATELY wasted!
Old 04-28-2006, 02:56 AM
MT Wallet's Avatar
ouch!
no burnouts for my baby
Bordo
04-21-2010 04:06 AM
dubsouth
05-09-2009 09:49 AM
rangerscott
08-19-2007 12:15 PM
Orangebutter
05-08-2007 03:55 AM
Andale
09-15-2005 02:41 AM
Quick Reply: Signs of a bad clutch
