seized Cente stand
Old Mar 4, 2010 | 07:02 AM
ownersince91's Avatar
Default seized Cente stand
Got a CBR6FP 93 model and my centre stand has sized , went to Garage about 6 months ago and was told to try and unsize it with wd40, it has now completley sized
Rang up garage and they are not sure if it just needs to be taken apart and cleaned , or it might need a new stand and bolt.
Any advice what to do, and what do i need , as currentley i cant adjust my Chain as cant use centre stand
Any help would be most appreciated thanks
Old Mar 4, 2010 | 08:13 AM
CBRme's Avatar
try PB Blaster from the parts store if that dont work try to take it apart yourself and clean it up good...
Old Mar 4, 2010 | 10:29 AM
Shadow's Avatar
You could try heating it with a heat gun on the pivot points and the tube and maybe gets the grease soft enough to move it..................
Old Mar 4, 2010 | 11:09 AM
CBRme's Avatar
i didnt know the 93 f2 had a center stand...mine doesnt????
Old Mar 4, 2010 | 11:55 AM
jnicola's Avatar
Remove it to save weight and buy a swing arm stand for cheap. They have them from harbor freight for $35~
Old Mar 4, 2010 | 04:21 PM
coldfire's Avatar
Neither does mine. Though I do have a 94. But I wouldn't imagine that it matters. Is it aftermarket?
Old Mar 4, 2010 | 04:51 PM
mariof's Avatar
i thought 91's were the only ones to have it. my 94 doesnt have 1 either. umm yea i would ditch it and only use it to work on the bike. kick stand is good enough and i never liked how much it hugs the wheel. you should be able to adjust you chain even with the tire down.
Old Mar 4, 2010 | 06:04 PM
Kuroshio's Avatar
Could be a UK / European model. A lot of the 'Fireblades' came with center stands. And its my bet the OP is English. His spelling of 'centre'.
Old Mar 4, 2010 | 06:18 PM
Bently600's Avatar
ya... I think the center stands were stock on the euro models.
it is harder to adjust the chain without a stand but it can be done.
sodahyogesh
Dec 15, 2013 03:46 PM
Rhodeislander
Nov 8, 2011 10:52 PM
Wheelie2
Nov 10, 2010 05:42 PM
rray12288
Sep 27, 2008 11:31 AM
Tahoe SC
May 5, 2008 09:58 PM
