Running funny?
Old Dec 5, 2012 | 09:56 AM
arc angel's Avatar
Default Running funny?
hi, my 1994 is running kinda funny, i think its running a little rich, it has to be full choked to run, at idle, and while you drive it, it can only got o half choke, or the bike dies while your cruising along, for some reason it doesnt seem like its getting enough gas! Can someone help answer my question?
Old Dec 5, 2012 | 10:41 AM
CorruptFile's Avatar
June 2013 ROTM
Make sure there is no leaks on the intake boots. The rubber gets old and cracks.
If they are good, give the carbs a good cleaning.
The choke doesn't change the amount of fuel is used, it changes the amount of air in the mixture ("chokes" the air, richens the mixture).
Old Dec 5, 2012 | 07:50 PM
partsguy's Avatar
I was going to say your pilot jets may be blocked but they only affect low rpm.Still getting this problem mid range and up? But if they're plugged up needing to run w/ the choke on or it dies at low rpm is the #1 suspect of clogged pilots.
You'll foul the plugs real quick if you keep this up.
Old Dec 6, 2012 | 01:06 PM
arc angel's Avatar
You'll foul the plugs real quick if you this up.
yes, even at mid range if i turn the choke down the bike literally will die no matter how fast im going... how would i go about changing the pilots?
Old Dec 7, 2012 | 06:50 AM
partsguy's Avatar
They probably can just be cleaned.Check the air screw settings as well,don't have a manual anymore or I could tell you how many turns out.If it is lack of fuel thats the problem it could be the fuel petcock is not going at full tilt.It has a diaphragm in the back which works off engine vacuum,they are rebuildable.
Old Dec 8, 2012 | 06:04 PM
CBR f2's Avatar
dont forget the idle adjuster... if its busted, popped out or even turned down, any and all carb related fixes or repairs may not have the effect... i would check that too... good luck
Old Dec 9, 2012 | 01:47 PM
arc angel's Avatar
ya i think my plugs are fouled up and I need to clean my carbs badly so thank you!
Old Dec 9, 2012 | 01:48 PM
arc angel's Avatar
my idle adjuster did fall out a couple days ago it needs to be screwed back in and carbs just need to be cleaned bad
dad0507
Oct 22, 2014 06:31 PM
mattrick
Sep 2, 2010 07:19 PM
killbillsnj
Jul 9, 2010 03:35 PM
berga
F2 Tech
Apr 9, 2010 03:59 PM
st3veo89
Jul 30, 2008 08:55 AM
