Rectifier regulator problems?
Old Dec 24, 2010 | 05:36 PM
PurpleKnight's Avatar
Red face Rectifier regulator problems?
Hello all, I have a 94 F2 and I've been having a couple issues. Its been overcharging the battery but only when I'm riding it hard for a long period of time. It starts to smell strongly of what I would describe as a "Rotten egg like" smell. Then The bike will eventually backfire then I'll start losing electrical components, mainly the turn signals will stay a constant rapid blink for a second then won't work at all. and then It will shut off. It will have absolutely no power.
I was told it was the regulator.
Any input about this, or where/what new regulator to purchase.
Thanks, PurpleKnight.
Old Dec 24, 2010 | 07:05 PM
Krux's Avatar
Take a digital volt ohm meter and test out to see how much power is going to the battery at idle. I knew when mine was going since it first over charged the battery and then eventually it wouldn't charge the battery at all.
Old Dec 25, 2010 | 12:37 AM
JesseAwesome's Avatar
Sometimes it'll give a low reading too.
Get the voltage at idel. Expect around 13 volts. Run it up to 3.5k rpm or so. Expect around 14 volts, if it's over 15 or under 13, it's something in the charging system, and 99/100 times on the F2 it's the regulator rectifier.
Old Dec 26, 2010 | 08:17 AM
Thanks a lot for the input guys. It turns out that it was reading 15v. It is the regulator. Do you guys have any sites that would be good to order one?
radman3120
Jul 7, 2017 09:38 AM
chrisrc
CBR1000F Wanted / Swap
Apr 19, 2010 03:03 AM
jzcbr600
Apr 1, 2007 07:52 PM
jeffrimerman
Dec 22, 2006 03:53 AM
Jspring0033
Feb 6, 2006 03:56 PM
