Rectifier Regulator
Old Oct 18, 2005 | 07:53 PM
93CBRdude's Avatar
Default Rectifier Regulator
the battery on my bike won't stay charged, so i checked the rectifier regulator. the part looked alright but the wiring harness that plugs into it looks burnt and melted. should i get a new rectifier regulator or is it the wiring?
Old Oct 19, 2005 | 12:54 AM
abadfish's Avatar
Default RE: Rectifier Regulator
You'll likely need to replace both the reg/rect and the wiring.
This may be of help:
http://forums.cbrworld.net/forums/140473/ShowPost.aspx
Old Oct 19, 2005 | 03:57 AM
wht92cbr's Avatar
hey does anyone know any place to buy wiring? my wires look burnt also. i live in california, the bay area to be exact. thanks for any help!!
Old Oct 19, 2005 | 04:47 AM
abadfish's Avatar
ORIGINAL: wht92cbr
Did you read the tutorial I posted?????????? Do so, then call your local Honda dealer. I know Mission Honda in Daly City usually carries the part in stock.
Old Oct 25, 2005 | 09:28 PM
PiMpBlueF2's Avatar
if it was the connecter that holds the 3 yellow wires together, and it was all burnt up, then thats ur problem, i had the exact same problem, and i went and bought a regulator for a 100 bucks for absolutely no reason, i just took off the burned up connecter, re-attached each wire to the other corresponding wires, heat shrink em, and go ridin!
paul_schmd
May 8, 2010 11:09 PM
chrisrc
CBR1000F Wanted / Swap
Apr 19, 2010 03:03 AM
cbrsixpack
The Hurricane Saloon
18
Jan 9, 2010 02:18 PM
shrek
Feb 5, 2008 09:58 AM
jeffrimerman
Dec 22, 2006 03:53 AM
