question for the experts
i just receved a 1994 cbr 600 f2. from what i was told it sat for five years. for some reason its not getting gas. if i put gas straight into the carbs it fires right up but if the gass tank is hooked up it wont even start. is the valve coming off the gas take vacumed controled?
If it is like my '92, yes. The vacuum line on mine goes to the left side of the motor. If you take it off of the motor and take the fuel line off the tank(the one with a clamp), you can suck on the vacuum line and fuel should come out of the fuel line if the fuel switch is on.
I would also change out the hoses in the fuel system. after a period of time gasoline produces a sticky "film" A.K.A Varnish. it will gum up everything and sticks like glue. and of course clean the carbs.
