question for the experts
Old Nov 21, 2005 | 08:55 PM
bubba_d_duck's Avatar
Default question for the experts
i just receved a 1994 cbr 600 f2. from what i was told it sat for five years. for some reason its not getting gas. if i put gas straight into the carbs it fires right up but if the gass tank is hooked up it wont even start. is the valve coming off the gas take vacumed controled?
Old Nov 22, 2005 | 02:45 AM
hikerduane's Avatar
Default RE: question for the experts
If it is like my '92, yes. The vacuum line on mine goes to the left side of the motor. If you take it off of the motor and take the fuel line off the tank(the one with a clamp), you can suck on the vacuum line and fuel should come out of the fuel line if the fuel switch is on.
Old Feb 1, 2006 | 10:33 PM
audiworks04's Avatar
yes, an uses all vacuum, the f3 uses a fuel pump, also if it set for that long the fuel could be geled up in the lines blocking flow or in the valve.
Old Feb 2, 2006 | 01:25 AM
transamlt1man's Avatar
I would empty the tank and clean it out with some acetone or something. Also the carbs should be cleaned.
Old Feb 2, 2006 | 11:00 AM
oleschool94's Avatar
I would also change out the hoses in the fuel system. after a period of time gasoline produces a sticky "film" A.K.A Varnish. it will gum up everything and sticks like glue. and of course clean the carbs.
vfrman
Sep 23, 2013 10:41 PM
jvalentine86
F2 Tech
Aug 9, 2010 08:13 PM
txsmainevent
Mar 14, 2008 01:21 PM
xpnugget
May 11, 2007 02:13 PM
wht92cbr
Nov 15, 2005 10:47 AM
