Question about Spark Plugs
Old 10-06-2005 | 07:10 PM
MofoSachem's Avatar
Default Question about Spark Plugs
Please let me know if I should continue with one thread for different questions or start a new one each time.
Ok I went to town anyway just for some learning experience, and here is what i have seen.
The air filter is mighty dirty, and has a build up of some brown stuff on it.. not much like a drip or two but its glossy where the cyclinders are.
I need to know how to take out the spark plugs, would i remove the radiator and go in from there or is there another method?
Also I took apart my fuel off switch to make sure the passage is clear, and want to make sure i put it together correctly. the order i have it is like this. Main Fuel tube with switch attachment. then i have the plate. with the smaller rubber facing the main large fuel tube. then i have on the outside. the tube that goes somewhere its a smaller tube. facing the same direction as the large tube outlet.
any links on how to change the plugs, would be a great help.
also what kind of coolant does an f2 take and how much in Standard. I got that manual and it doesnt tell you any capacities... I was considering purchasing the clymers guide.
Old 10-07-2005 | 06:18 PM
clemson725's Avatar
Default RE: Question about Spark Plugs
Air rachet if you got one.
baseballkid
10-04-2012 07:48 AM
Tort93f2
03-16-2012 06:14 PM
ahbrown4057
05-05-2011 12:34 PM
alexr40
03-05-2007 03:28 PM
mkhaynesaz
02-23-2007 04:10 PM
Quick Reply: Question about Spark Plugs
