Newbie Question; Spark Plugs
Do I really have to remove the tank and air box to change the plugs? It looks pretty tight down there and my hands are not small. I pulled one wire, and that seemed difficult. Also, who sells plugs (besides the Honda dealer) and what type? Thanks.
You can buy spark plugs for your bike at auto parts stores. They may not have them in stock but usually have them the next day much cheaper than buying them from the dealer.
You can probably find them online. Check Amazon. As far as what type it'll list that in your owner's manual.
I've changed all 4 plugs without removing anything but the side access panels/vents. Took a variety of extensions, I don't have the smallest hands, but they aren't huge either, but it can be done.
I used the NGK Iridiums mentioned in the earlier post: CR9 heat range.
Well I haven't tried to change plugs yet but I did go out today to start it up. It idled for a few seconds then died. Tried it again, same thing. It won't idle and every time I give it the slightest amount of gas it dies. Now it wouldn't start and backfires pretty bad. What the hell am I doing wrong that I can't get this thing to run??
