powerwashing engine
Old Dec 20, 2009 | 12:15 AM
LMP1327's Avatar
Default powerwashing engine
I have my bike completely apart, and would like to clean the engine. I can take it to work and spray degreaser(overspray remover) on it and then powerwash it, but I'm worried about some of the seals.
- output shaft seal, where the front sprocket is
- shifter seal, both of these are right by eachother and that is the dirtiest area of the engine.
- the sensors coming out of the two side casings.
Will the degreaser affect my seals? will a powerwasher be too much pressure for the seals?
Old Dec 21, 2009 | 04:39 PM
Krux's Avatar
I never like forcing water at my engine. Just think miss a little bit and get it in the carbs..ugh what a nightmare that would be.
Old Dec 22, 2009 | 11:38 AM
mightymouse657's Avatar
I know what that is like. Freak rain storm in the middle of cleaning my carbs filled the head with water. What a major pain in the *** that was.
Old Dec 22, 2009 | 06:12 PM
Krux's Avatar
Oh god that had to be a nightmare for you. I bet you were pissed off as hell at that point
Old Dec 25, 2009 | 01:30 PM
LMP1327's Avatar
My bad I forgot to tell you that I had the carbs off as well as all wiring except for the wires coming out of the two side cases.
I did powerwash my motor the other day and I think it turned out great. I sprayed degreaser but was careful not to spray it directly on seals/etc.
I stuffed rags in the spark plug holes and the intake. I didn't spray water directly on the seals either.
The front sprocket area came pretty clean. There was some stuff up in there i couldn't get out though.
I will post a before and after pic tonight.
Old Dec 25, 2009 | 10:06 PM
LMP1327's Avatar
Well I couldn't find my before pic but I think it turned out pretty good what u guys think?
Old Dec 26, 2009 | 03:09 AM
f2first_love's Avatar
Looks good! I wish I would had done that before I split my engine case. Now I have a bunch of parts and want to repaint my dirty motor. Another project I need to research before tackling...
What specific cleaner did you use?
Old Dec 26, 2009 | 03:10 AM
Is your engine resting on the exhaust pipes???
Old Dec 26, 2009 | 03:33 AM
LMP1327's Avatar
I used an overspray remover/degreaser I'm not sure the brand.
And yes, it was. I have it bolted to the frame now I didn't realize what I was doing.
lanceam24
F2 Tech
Feb 21, 2011 11:45 AM
knifemaker87
F2 Tech
Sep 17, 2010 09:21 AM
julius1
CBR Zone
Jan 4, 2010 11:32 PM
98formulaLS1
Aug 24, 2009 10:04 AM
Workwell
Jan 14, 2009 10:02 PM
