Noob question about torque?
Hi, I am new to this and have been using the search tool but can't seem to get a definate answer on a torque wrench. Should I but a 1/2" Drive Torque wrench or a 3/8"? The 1/2" i am looking at is 20-250 ft-pounds, is that too much?
What wrench would I be able to use for most applications as in changing brakes, tires, miscellaneous engine torques?
RE: Noob question about torque?
From what I can see in my manual. The highest torque areas are the rear axle nut (69 ft*lb), steering stem nut (76 ft*lb), and the swing arm pivot bolt nut (80 ft*lb). If you can get a 3/8" drive that will handle these torques, I can't see spending the extra for a 1/2" drive unless you are going to use it on cars, trucks, farm equipment, jet aircraft, or your neighbor only has a 3/8" drive.
cpark_12
08-19-2011 09:35 AM
justin1982z28
08-31-2007 09:10 AM
