new memeber fuel question
Old 10-11-2008, 09:35 AM
mroc905's Avatar
Default RE: new memeber fuel question
ok didnt see your post woo untill after i posted the picture. so what connects to the nosel underneath? im going to go pull the fuel line out of the T to see if fuel runs out
Old 10-11-2008, 10:11 AM
mroc905's Avatar
should gas be coming out of the nozzel if the vacumm hose is disconnected?
Old 10-11-2008, 10:29 AM
woo545's Avatar
I don't recognize the petcock. Make a post in the General tech section with that picture. See if someone else recognizes it.
Old 10-11-2008, 10:33 AM
mroc905's Avatar
i just pulled the fuel line off of the petcock and there was a tiny amount of fuel in the line but nothing came out of the nozel so i think the petcock is clogged somewhere shouldnt the gas be coming out of it?
Old 10-11-2008, 12:49 PM
Rickracer's Avatar
In your picture, the hose in the front is the vacuum port and should have a hose from the #2 carb connected to it. The fuel hose port should be on the opposite side of the petcock. [8D]
Old 10-11-2008, 08:05 PM
GSX_RDR's Avatar
Unless you have the vacuum line connected to the petcock and the engine running (or you can suck on the hose todraw a vacuum), on the fitting shown in your picture in the big circle, you won't get any fuel. Connect that, and you should be runnin'
Old 10-11-2008, 08:43 PM
mroc905's Avatar
got the problem fixed, i ran a hose from a gas can up on top of a shelf down to the T fitting and she fired right up so i took the tank back off and took a look at the petcock and it was all clogged up with tape or something from the previous owner. also cleaned the carbs all up nice since i had the tank back off nowthey look brand new
Old 10-11-2008, 09:39 PM
woo545's Avatar
#2 carb? Really? Stock is #1...though I really don't think it matters which.
Old 10-15-2008, 02:13 PM
I don't recognize that petcock either.
Old 10-15-2008, 02:20 PM
edwardtn's Avatar
Looks just like my stock 94 petcock, the photo is just taken from the vaccum line (throttle/right) side.
kd185
07-12-2011 09:52 PM
killbee
08-04-2009 10:11 PM
cr33pinF4I
02-10-2008 08:04 PM
nmoulton1979
04-24-2007 04:49 AM
cookie
11-27-2005 08:36 PM
Quick Reply: new memeber fuel question
